If so then where do I change the bitrate? In TMPGEnc? And how does the higher bitrate effect the file size? Thanx
Answer: probably "YES", if the video is being starved of enough bits to render the video properly. (The reason I said "probably", is that if the video is not bit starved, then increasing the BR does not result in better video - for instance, a BLACK SCREEN (an extreme case, no doubt!) can easily be rendered at 500kbps. Increasing this BR to 5Mbps doesn't do anything but increase file size.)
File size (in bytes) is equal to:
(VIDEO_TIME_IN_SECONDS x BITRATE) / 8
So, it is easy to see that doubling the bitrate will double the file size.
Bitrate can only be changed by an encoder (CCE, TMPG, etc.).
Higher 2.0 AAC bitrate from Ripbot
By jntaylor63 in forum Blu-ray RippingReplies: 6Last Post: 3rd Nov 2012, 16:22 -
transcoding mp3 to higher bitrate questions
By spiritgumm in forum AudioReplies: 6Last Post: 28th May 2011, 16:46 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
Will the quality increase if the bitrate is higher after conversion?
By Choppa in forum Authoring (VCD/SVCD)Replies: 16Last Post: 3rd Jul 2007, 09:23
