Can you configure IFOEDIT to automatically start the authoring process after DVD2DVD-R has finished creating the resized files?
If so How?
Thanx
After you select the file to rip in DVD2DVDR, select the third tab at the top. There should be a spot to check that says "Autho if possible". I don't use this feature so, can't tell you if it works.
Question about how to scan without image/OCR program
By jimdagys in forum ComputerReplies: 1Last Post: 9th Dec 2009, 23:33 -
Best Of The Best Program Question ??
By bludude in forum Blu-ray RippingReplies: 6Last Post: 11th Aug 2009, 21:25 -
Student TV Program Question
By richrider in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2009, 09:16 -
Another question about best program
By Kurgan71 in forum Video ConversionReplies: 9Last Post: 3rd Aug 2008, 06:03 -
FAVC(program) Question.
By cowboysroy31 in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 03:20
