have ripped a DVD that is just over 4 hours and about 8GB.
I used CladDVD XP to frameserve for me so I can convert with TMPGEnc.
The trouble is the Wav file it made was about 2.8 GB which from what I have been told, is over the limit of 2GB windows can handle. If I try to add it to TMPGEnc I don't get the audio!
I did cut a part of the Wav file and have managed to convert the first 1hr 15 mins ok.
I did get Clad to cut the film into 1GB vobs but it too big for my computer and it locks up!
I need to be able to convert the film in 3 parts as I don't have a very fast computer ( Duron 800/ 256MB) and it saves me having to cut it later.
What can I do to fix this? Tried DVDx but crap quality. I need Mpeg files I can use with VCDEasy as I like chapters.
All help appreciated
If your frameserving with DVD2AVI you could choose to demux audio into ac3 audio file. It will be about 800MB's for a four hour movie. There are programs that will convert the ac3 into mp2/SVCD format. Some versions of Tmpeg(2.54 and earlier)will convert ac3 to mp2.
TMPGEnc wont except an AC3 or Mp2 file as I tried. I am using TMPGEnc 2.5 which is the only full Mpeg2 version I have.
I think I have it sorted now as I used DVD2AVI to just do a few vobs at a time which keeps the wav file size down. I like to convert under 80 min parts at a time anyway so its ok
Thanks for your reply -
Just another quick suggestion... when ripping you could have chosen to rip a few chapters at a time... ie if it's 21 chapters and you want to split across 3 VCD's then take the total movie time, divide by 3, and try and figure out which combination of chapters will give you a good fit... ie 1-6 then rip 7-15 into another directory, then rip the rest into another one...
Then run DVD2AVI to frame serve each of the 3 sections creating 3 D2V files, and 3 WAV files. Then encode each grouping seperately with TMPGENC...
I would think that this would work better than using selected VOB's in DVD2AVI, because I believe that chapter boudries may cross two VOB files causing you to break right in the middle of a scene... if you do it my way your break would be in tune to the end of a chapter... -
I did get it sorted by doing 3 vobs with DVD2AVI at a time, which is about what you said.
trying to email MOD video clip, too big. How do I convert??
By Crunchberry in forum Video ConversionReplies: 8Last Post: 22nd Mar 2012, 23:55 -
Can't convert very big file
By Julio33 in forum MacReplies: 3Last Post: 16th Dec 2010, 15:18 -
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 01:41 -
Convert analogue to avi - 1 GB a minute, look too big
By ManUtdFans in forum Capturing and VCRReplies: 7Last Post: 29th Mar 2009, 08:16 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
