  1. I switched from 98SE to Win2k - and this is what's up...I can no longer unlock all the files off of a DVD. I could in 98SE, but not in 2k - this applies with all ripping software. I thought this may be an ASPI thing, but I can't install any of my burner apps (Nero makes it crash in an oh so wonderful fashion). I was just wondering if anyone has had something like this happen and if they got a fix-ish for it...
    Sep 2000
    Ga Usa
    hmm.. thats an odd problem. when i upgraded to win2k, i couldn't play dvds on my computer, untill recently. for the appz that frezze, you probalby have the WIN95-98 ones, try upgrading those.
  3. Member craigarta's Avatar
    Jun 2001
    Cascade Mountains
    I had a problem with that. The easiest thing for me was to do a a clean install that way you don't the WINNT and WINDOWS folders mix ups.
    Apr 2001
    Dallas, Texas USA
    If you play the DVD for a few seconds with your PC's DVD player software, it ought to unlock all the files for the ripping software. This has worked for me.
    I had problems playing DVDs after a ME->2000 upgrade (got an overlay error), but figured out that having Netmeeting Desktop Sharing running in the system tray was causing this problem.
