Hi,
I have two questions,
1. I can make vcds into an mpg file but the file is to big to fit on a cd, what can I do(I use dvdx)?
2. The movie is 1.55min long and my cd is 80min max, help??
thx for your time.![]()
well the conventional way to make a vcd movie is to have one movie across two cds (vcds). However their are ways to fit your movie on one vcd but that requires extra reading on this site. This is too much to explain really... just follw direction on the site.
You could use DivX and make an AVI, then put it on a data CDR, but if you want them on VCD you have to split the .mpgOriginally Posted by Toka
Fit it on 2 VCD's2. The movie is 1.55min long and my cd is 80min max, help??
KingJohns Guide Splitting Mpeg1
If you tried to shrink it down to fit on 1 VCD, the quality would be bad, and it would no longer be a VCD, you would have an XVCD which might not even play. Use the guide.... -
I know how to split, I was just hoping I could somehow get it all on on cd but your right, the quality would be very bad, thx for your help everyone.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34
