Everything seems to work great except burning the VOBs to disk, Nero gave me a disk error and the guide says not to use Nero. I tried Record Now, but it says that it can't find a drive(Sony DRU-500a). I updated the latest firmare from Sony and I can't find an update for Record Now. Is there something better to use or how can I get one of these to work? Thanks
Hi jimbobnewbie,
You could download the update for RecordNow DX 4.6 from :-
http://dl1.easy.co.jp/rndx46_e/sonyos/regist2.html
After updating your software, hopefully you should be able to see your SONY drive. -
You need the latest PX-Engine update, try here:Everything seems to work great except burning the VOBs to disk, Nero gave me a disk error and the guide says not to use Nero. I tried Record Now, but it says that it can't find a drive(Sony DRU-500a). I updated the latest firmare from Sony and I can't find an update for Record Now. Is there something better to use or how can I get one of these to work? Thanks
http://downloads.stompinc.com/support/PxEngineUpdate320.exe -
Thanks for the attempted help, but I updated both of the softwares that you 2 suggested, and it still won't see my drive. Any more suggestions? Thanks again
Originally Posted by jimbobnewbie
I had the same problem kinda, I use recordnow Max, not the one that cam with the drive, mostly because I already had it, It worked fine for a month than one day it just did as u say I started it and it said no recordable drive, I downloaded the new engine from the site and it works again, only thing it can be is a driver on your system that is not letting it load the drivers it needs. This is just my thoughts, but it happens a lot with software, With out doing a clean install and then loading it first really do not know, mabey load a dual boot and try it that way with just it loaded, might work then u can load your other software until u find the other one causeing your problem. Well wish I could be more help, Then again it could be a MB Bios problem.
Are u using the program that came with it. and do u have DLA and nero loaded.
You can try checking inside your computer and see if everything is connected properly. Other hardware could be conflicting with the drive.
you can see if there are any software conflicts with the drive (irq information)
You can try reinstalling windows. I find this to help hen drastic measures need to be taken.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
