i know people say that they get off sync with an avi but when i ripped my video it was ripped straight as an mpeg. i have tried to cut out the sound and then cut out the video with tmpegenc and then put them back together, but it doesn't seem to be working. please help.
What did you use to convert the VOB's DvdX V2 ? has problems.
If your DVD rip has sound sync problems, no amount have saving out and converting will fix it.
Vdub
1, Audio >Full processing mode
2, SAVE AVI (test.avi)
3, Audio > WAV audio > Your new AVI (test.avi)
4, Audio > direct stream copy
5, Video > direct stream copy
6, SAVE AVI (test.avi)
That saves the audio out uncompressed, then puts it back into the original AVI, if that is now ok, you can reload the new test.avi and use direct stream copy for video, but use full processing mode for audio but this time select compression and a MP3 codec, then SAVE AVI -
actually i captured the video with ulead video studio and that changed it to an mpeg when i outputted it.
Sound out of sync in Avidemux
By Lambert in forum EditingReplies: 21Last Post: 19th May 2010, 01:59 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 11:19 -
Slideshow with sound in sync
By tin2tin in forum User guidesReplies: 0Last Post: 18th Jun 2008, 05:07 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 10:31 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 21:11
