When using TMPGE to make my mpg, I don't like using the "Center" or any other options in the "Video Arrange Method" on the Advanced tab. They don't come out right. I have been somewhat successful in defining my own aspect ratio size based on the original aspect ratio of the movie. I would like to know:
Isn't there a mathmatical equation or some calculation to correctly increase the aspect ratio of a movie while keeping the original proportions? Adding 100 to each pixel doesn't give the right picture size. I want to know how to increase the size and keep the picture looking right.
**NOTE: I am making SVCDs
The normal setting for this is full screen > Keep aspect ratio
The output will be proportionally correct, if you want to experiment, then use clip frame functions, the preview is showing what it looks like!, udjust the values until it looks they way you want it to look
KingJohn, this helps a little, but TMPGE gives the following options for Full Screen:
Full Screen
Full Screen - Keep aspect ratio
Full Screen - Keep aspect ratio 2
Which one do you suggest?
Also, your comment about using clip frames to see what it will look like is a great suggestion. Thanks! -
Don't use Full Screen as it doesn't keep the aspect ratio of the file. Use either one of the Full screen, keep aspect ratios'.Originally Posted by emaildavet
I already told you which one
Oh sorry
I missed a word out, no wonder you asked again
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
Aspect Ratio
By thesuperhemanshow in forum EditingReplies: 0Last Post: 5th Jan 2009, 17:36 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 08:21 -
aspect ratio help
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 14:41 -
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 03:43
