Is there a way to tell on a DVD which file(s) are the menu and chapters to be able to then select them with DVD Decryptor. All I want is the movie, menu, and chapter. I don't want all the other extras.
Thanks in advance.
Kizer
With decrypter, I think all you can get is the Main movie. Ifoedit, I think is what you want. I don't use it so I can't help you.
When DVD Decrypter is open and your DVD movie loaded and its contents displayed in the window. Go to the 'Edit' drop down menu and select 'Select Main Movie Files'. That 's the movie, as for the menu it would either be the VIDEO_TS.VOB or the VTS_**_0.VOB file or both. The ** is the same titleset number as your movies's VOBs and proceed as normal.
You may also want to select the corresponding IFO files for each one too.
Do all this in 'File' Mode.
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 02:11 -
Burning a dvd so that it keeps the orignal menus/chapters..
By Dchristy47 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2010, 03:11 -
Preview bluray/avchd dvd menus,chapters
By vandaLo in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2010, 14:55 -
Two Different Concert In One DVD with menus, chapters, play all Functions.
By madman1987 in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 20:17 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 16:41
