Can anyone tell me how to make an audio dvdr ?
I am using InstantCD+DVD and i am using the UDF audio DVD setting and using wave files. It burns the disc but it will not play in a dvd player.
Do the wave files have to be 48khz instead of 41khz.
Is there a program that does the convirting for you like when you drag an mp3 into nero it converts it to a wave when making an audio cdr.
Any idea's please.
The DVD-AUDIO specification is just as complicated as the DVD-VIDEO specification. To produce a bonafide DVD audio disc you will need to use a special authoring tool i.e the audio equivalent of a DVD video authoring tool. Right now I do not know of any commercial tools that are available to the average joe.
The workaround is to author a DVDvideo and use whatever audio you need. One of the easiest methods would be to create a menu and have separate chapters for each piece of music. Each chapter would need an associated picture like a slide show.
Hope this helps.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
