When many artifacts occur in my VCD mpg test-result (using TMPGEnc) I'm doing this wunderfull trick:
I open the AVI in VirtualDub and select the video filter 'Resize' with following parameters
- New width : doubling the orginal
- New height : doubling the orginal
- Filter mode : Precise bicubic (A=-1.00)
Then I framserve to TMPGEnc and I have an nice clear and still scharp movie (even when it is captured in lower resolutions like 352 x 288/240).
Whats happend behind:
When scharp objects are moving over the screen artifacs will occur.
Soften the image by doubling the size will encoded in TMPGenc in that big images and after than downsized the size that you specified in TMPGenc video settings and your scharp movie is back.
Results 1 to 1 of 1
Removing artifacts
By IsAB in forum EditingReplies: 6Last Post: 15th Feb 2011, 02:24 -
Looking for artifacts
By Caple in forum RestorationReplies: 18Last Post: 1st Oct 2010, 20:27 -
Tricky out put for Full HD 1080P in After Effects
By Chikyujin in forum DVB / IPTVReplies: 5Last Post: 6th Apr 2009, 11:37 -
A tricky Driver for Capture Device Needed
By Digiliz in forum Capturing and VCRReplies: 9Last Post: 8th Jul 2008, 11:26 -
Tricky
By bfong in forum Authoring (DVD)Replies: 7Last Post: 27th Jun 2007, 08:56
