Results 1 to 11 of 11
  1. I used the vcdimagerGUI Easy to make .bin and .cue files and I tried to make chapters while using it but when I play the vcd in my vcd player it doesn't allow me skip to the next chapter. Any idea what I did? Also, I used Nero 5.5 to burn the .cue file so it would become a VCD. thanks
    Feb 2001
    Berlin, Germany
    I suggest to use CDRWIN instead of Nero.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    No. You may post the .xml here.
  3. is this what you mean?
    <?xml version="1.0" ?>
    <!DOCTYPE videocd (View Source for full doctype...)>
    - <!-- Made with VCDImager Easy v0.9.7
    - <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0">
    <option name="relaxed aps" value="false" />
    - <info>
    <album-id />
    <volume-count>1</volume-count>
    <volume-number>1</volume-number>
    <restriction>0</restriction>
    </info>
    - <pvd>
    <volume-id>VIDEOCD</volume-id>
    <system-id>CD-RTOS CD-BRIDGE</system-id>
    <application-id>CDI/CDI_VCD.APP;1</application-id>
    <preparer-id />
    <publisher-id>VCDImager Easy v0.9.7</publisher-id>
    </pvd>
    - <filesystem>
    - <folder>
    <name>CDI</name>
    - <file src="C:\MY DOCUMENTS\DOWNLOADS\VCDIMAGEREASY V0.9.7 WITH GNU VCDIMAGER V0.7.9\Cdi\CDI_IMAG.RTF" format="mixed">
    <name>CDI_IMAG.RTF</name>
    </file>
    - <file src="C:\MY DOCUMENTS\DOWNLOADS\VCDIMAGEREASY V0.9.7 WITH GNU VCDIMAGER V0.7.9\Cdi\CDI_TEXT.FNT">
    <name>CDI_TEXT.FNT</name>
    </file>
    - <file src="C:\MY DOCUMENTS\DOWNLOADS\VCDIMAGEREASY V0.9.7 WITH GNU VCDIMAGER V0.7.9\Cdi\CDI_VCD.APP">
    <name>CDI_VCD.APP</name>
    </file>
    - <file src="C:\MY DOCUMENTS\DOWNLOADS\VCDIMAGEREASY V0.9.7 WITH GNU VCDIMAGER V0.7.9\Cdi\CDI_VCD.CFG">
    <name>CDI_VCD.CFG</name>
    </file>
    </folder>
    </filesystem>
    - <sequence-items>
    - <sequence-item src="C:\My Documents\Server\hday2001-03-11.vidf\March 11, 2001.mpg" id="sequence-00">
    <default-entry id="chapter00-00" />
    <entry id="chapter00-01">390.000</entry>
    <entry id="chapter00-02">663.000</entry>
    <entry id="chapter00-03">1051.000</entry>
    <entry id="chapter00-04">1300.000</entry>
    <entry id="chapter00-05">1550.000</entry>
    </sequence-item>
    </sequence-items>
    </videocd>
    I used the VCDImagerGUI Easy and I put in the times where each chapter was to start but when I play it in the DVD player (standalone) the VCD stops when I press the button to get to the next chapter. If you have time could you IM me and maybe help me out. IM is bostran1. thanks
    <font size=-1>[ This Message was edited by: dmben on 2001-09-03 16:05:29 ]</font>
    Feb 2001
    Berlin, Germany
    I tried same thing (chapters without menu) with VCDImager0.7.9 too and it did not work. That's a problem of our dvd players. But it work perfectly with VCDImager0.7.10.
    Unfortunatly VCDImagerEasy does not work with v.0.7.10.
    I guess you want to use a GUI, so I suggest to use TSCV. Today I used v.072rel2, probably it is not the newest.
    TSCV can create (yes, actually VCDImager do) (S)VCD with chapter and menus. If you want a VCD 2.0 as above, just delete the <pbc> section off the .xml.
    Hope this helps.
    <font size=-1>[ This Message was edited by: Truman on 2001-09-03 16:16:13 ]</font>
  5. I'll try it with the other Guis and such and see if it works. I went to the tools page, clicked on TSVC and the page wasn't found. Know anywhere where I can get it?
    _________________
    ~Ben
    <font size=-1>[ This Message was edited by: dmben on 2001-09-03 16:24:25 ]</font>
  6. I got the version of TSCV from the tools sec and I got VCDImager version 0.7.9 and something goes wrong when I try to create the cue/bin. no xml is generated and it says that the file is wrong. I am 99% sure it has something to do with TSCV and/or the version of VCDImager I got. This is what the log in TSCV says if it helps:
    Starting VCDxBuild process...
    TSCV will not react until VCDxRip has finished.
    Logfile:
    ++ WARN: initializing libvcd 0.7.9 [cygwin/i686]
    ++ WARN:
    ++ WARN: this is the UNSTABLE development branch!
    ++ WARN: use only if you know what you are doing
    ++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
    ++ WARN:
    ++ WARN: this VCD type should not contain MPEG1 streams
    INFO: writing track 1 (ISO9660)...
    INFO: writing track 2, MPEG1, NTSC (352x240/30fps), 1 audio stream...
    finished ok, image created with 158891 sectors [35:18.41]
    VCDxBuild finished
    and the xml:
    <?xml version="1.0"?>
    <!DOCTYPE videocd PUBLIC "-//GNU//DTD VideoCD//EN" "http://www.gnu.org/software/vcdimager/videocd.dtd">
    <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="svcd" version="1.0">
    <info>
    <album-id></album-id>
    </info>
    <pvd>
    <volume-id>NEW</volume-id>
    <application-id></application-id>
    <preparer-id>GNU VCDIMAGER 0.7.7 CYGWIN/I586</preparer-id>
    <publisher-id>TSCV06r1</publisher-id>
    </pvd>
    <filesystem>
    <folder>
    <name>SEGMENT</name>
    </folder>
    </filesystem>
    <sequence-items>
    <sequence-item src="C:\WINDOWS\Desktop\hday2001-03-11.vidf\March 11, 2001.mpg" id="sequence-0">
    <entry id="entry0-0">0.000</entry>
    <entry id="entry0-1">390.000</entry>
    <entry id="entry0-2">663.000</entry>
    <entry id="entry0-3">1051.000</entry>
    <entry id="entry0-4">1300.000</entry>
    <entry id="entry0-5">1550.000</entry>
    </sequence-item>
    </sequence-items>
    <pbc>
    <playlist id="selection-0">
    <prev ref="end-1"/>
    <next ref="selection-1"/>
    <return ref="end-1"/>
    <wait>0</wait>
    <play-item ref="sequence-0"/>
    </playlist>
    <playlist id="selection-1">
    <prev ref="selection-0"/>
    <next ref="selection-2"/>
    <wait>0</wait>
    <play-item ref="entry0-1"/>
    </playlist>
    <playlist id="selection-2">
    <prev ref="selection-1"/>
    <next ref="selection-3"/>
    <wait>0</wait>
    <play-item ref="entry0-2"/>
    </playlist>
    <playlist id="selection-3">
    <prev ref="selection-2"/>
    <next ref="selection-4"/>
    <wait>0</wait>
    <play-item ref="entry0-3"/>
    </playlist>
    <playlist id="selection-4">
    <prev ref="selection-3"/>
    <next ref="selection-5"/>
    <wait>0</wait>
    <play-item ref="entry0-4"/>
    </playlist>
    <playlist id="selection-5">
    <prev ref="selection-4"/>
    <next ref="end-1"/>
    <wait>0</wait>
    <play-item ref="entry0-5"/>
    </playlist>
    <endlist id="end-1"/>
    </pbc>
    </videocd>
    <font size=-1>[ This Message was edited by: dmben on 2001-09-03 17:04:26 ]</font>
    Feb 2001
    Berlin, Germany
    There is an otion to save the .xml before create cue/bin.
    You did create a SVCD image, that's the WARN, but it also reported "finished ok"
    Here you will find the latest version
    VCDImager 0.7.10.
  8. still didn't work. Nero won't burn the .cue for some reason.
    Feb 2001
    Berlin, Germany
    Download a demo of CDRWIN here.
    Feb 2001
    Kalmar, Sweden
    Don't really know what you mean by Nero not finding the .cue
    But as my "standard tip" is: put the .bin and .cue in c:\temp (or similar) and change in the .cue to match the dir/file . (A line should be "BinFile.bin&quot
    It should here be "c:\Temp\BinFile.bin" it should ALWAYS work fine!
    Magnus Jensen
    A.K.A Geezus
  11. Nero does not correctly burn CUE/BIN images.
    It may be fine for a single track disc, but for anything more than that (which are all VCDs), it creates problems. Most signficantly, the PBC authored content will probably not work.
    I strongly suggest you use CDR-Win, Fireburner of CDRDAO.
    Regards.
    _________________
    Michael Tam
    <font size=-1>[ This Message was edited by: vitualis on 2001-09-04 05:21:51 ]</font>
