Well I got a Digital Video Camera recently, which has DV output.
My computer currently as the All-In-Wonder RADEON 32Mb DDR Tv card. I do not have a firewire card in my computer.
To transfer video from my camera to my computer, what will give me the best quality?
S-Video Out from camera and into AIW S-Video
OR
Purchase firewire card and connect DV out to this card?
TIA
You should use firewire, as with DV it is a file transfer, the encoding/compression is done in the camera. If you transfer using firewire there is no quality loss at all, same if you send back to the camera. The only re-encoding takes place when you edit in a NLE, and the program encodes the transitions/titles etc.
As long as your PC specs are up to it, and you have enough hard drive space (approx. 13Gb an hour, plus whatever you want to do as far as editing/encoding to mpeg etc.), you should be OK, and will have the best possible quality to start with. -
OK Thanks
I will buy a firewire card.
Does this firewire also do the audio or is it strictly a video transfer?
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 11:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 21:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 15:52 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 13:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 16:25
