I want to merge 2 svcd files into one. The movie part1 on cd1 is 2130 bitrate, and cd2 has 2050 bitrate. How can I use TMPGEnc to merge 2 files or any other software.
The problem I have it that when I use TMPGEnc tools and merge 2 files, the full movie in the middle, where cd2 starts - is losing audio sync with video. I don't know what's the problem. I think that two CDs were encoded in VBR and that's why I lose sync. How can I than successfuly merge 2 files together.
Thanx
=[ vinchi007 ]=
The bitrate is irrelevant. The audio sync problem is probably due to the way the MPEG's were split in the first place. If the JOIN tool in TMPGenc is giving bad output, try using AVISynth to join the two together, or resplit them using tmpgenc, trimming the ends that are to be joined just a bit more.
Impossible to see the future is. The Dark Side clouds everything...
VOB merger/splitter/editor
By altavistasf in forum EditingReplies: 5Last Post: 17th Oct 2010, 21:16 -
Best merger or joiner without re-encoding software?
By diodox in forum EditingReplies: 2Last Post: 18th Aug 2010, 06:18 -
i-media file merger
By GimpGuy2000 in forum EditingReplies: 2Last Post: 4th Dec 2008, 10:56 -
XM-Sirius Merger
By Epicurus8a in forum Off topicReplies: 13Last Post: 17th Jun 2008, 06:19 -
MP3 Merger
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 3Last Post: 10th Jun 2007, 01:53
