I have a WinTV that i tried to capture using YUY2 & Huffy, but have no luck. I can capture without problem, but when play back the avi file there is no picture but sound only. If I use 24RGB with huffy or picmjpeg, everything work fine.
Can someone let me know if is it a driver problem or any thing else.
I have no such problem with my WinTV-Go. My first suggestion would be to reinstall Huffyuv. After that, make sure you have the latest VFW capture drivers for your OS. Updating to the latest version of DirectX may also have an effect.
-Cart
http://www.geocities.com/lukesvideo/index.html -
Thanks Cart Wheel,
I tried capture under winme & win2k with avi_io and virtualdub. I have dirx 8a and lestest driver from Hauppauge and still have no luck. It's been since I got this WinTV Go card about a month a go.
BTW, I learned a lot from your site.
YUY2 Vs. UYVY Capture
By W_Eagle in forum Capturing and VCRReplies: 2Last Post: 11th Jul 2008, 11:15 -
New ADVC110 does not show up as available capture device
By tonyp2 in forum Capturing and VCRReplies: 16Last Post: 12th Jun 2008, 22:01 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
what is the best format when capture from tv show?
By sumeshkri in forum Capturing and VCRReplies: 10Last Post: 23rd Feb 2008, 19:35 -
YUY2 or RGB for vhs capture?
By RH+ in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2007, 13:46
