I have "excel saga" vol 1, 2 and 3 and dvdxcopy 1.4.1 When i copy the vol 3, and from the first disk i select a chapter that is on the second disk, doesn't appear "please insert disk 2" but automatically start the last chapter of the disk. How can i fix this problem manually?
thanks
hmmm, for the second disc do you have it set in dvdxcopy for it to start normally like the first disc? Or you could try the second disc with it set on start with menu. Sometimes dvdxcopy gets things a little messed up on some titles. Best of luck
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
