Earthlink's is the best all-around. Everything else I've seen has to ask you to block certain windows or add certain taskbar tabs as "targets" this is booty because most pop-ups are randomized so you end up with a ginormous amount of targets. Go to IOWrestling.com and see why pop-ups are bad. Earthlink blocks all pop-ups. I want Earthlink's blocker but i dont want Earthlink. Can I get any suggestions on what I should use from the people of VCDHelp use.
Try popupkiller it's free and you can set the number of windows that are allowed to be open.
Pop-up Stopper from Panic Ware (www.panicware.com)
The new released Netscape 7.01 got the popup ad blocker included. You have to set the preferences for it to work.
Look in the options...
They are not turned on by default. You can set it to block ALL popups or popups from specific sites.
Regards.Michael Tam
w: Morsels of Evidence
What is this pop up on Vhelp ?
By Noahtuck in forum FeedbackReplies: 3Last Post: 18th Aug 2010, 15:08 -
Spyware / Adware / Pop-up HELP!!!!
By DVWannaB in forum ComputerReplies: 5Last Post: 13th Oct 2008, 19:16 -
Pop up doesn't go away
By jyeh74 in forum ComputerReplies: 20Last Post: 22nd Sep 2008, 04:54 -
Pop-up video
By uniks in forum Newbie / General discussionsReplies: 19Last Post: 29th Aug 2008, 21:44 -
A pop up
By imkool in forum Software PlayingReplies: 1Last Post: 19th Feb 2008, 12:11
