Hello to everyone! I'm new here. I recently encountered some problems when I've tried to make a VCD. I got the video file from an FTP. It was around 850 MB, in WMV format. From what I read on this site, I renamed it in ASF format, and divided it into 3 smaller parts(each of which were about 250 MB in size), using ASF Tools. After this, I wanted to convert it to MPEG, using TMPGEnc, but when I started the conversion of just one of the parts, TMPGEnc predicted that it would take about 90 hours to complete. Anyways, I left it overnight, and in the morning, there was only about 8% of the file done, which is unusual, since I can usually convert a file twice the size, in AVI format, not ASF, in one night. If there's anyone that can tell me why this is happening, what I should do, anything, I would really appreciate it. Thank you very much!
get stoik video converter from www.stoik.com
or use vdub 1.3c and frameserve it to tmpgenc -
Thank you for the response! I got Stoik converter, but that only allows me to convert WMV/ASF to AVI. I'm affraid that if I convert it to AVI first and then to MPEG, I will lose some of the quality. Is there any method to convert it to MPEG directly from WMV/ASF. Does anyone know of another method that may solve my problem? Thank you very much!
Conversion tp AVI will not lose much quality - it depends on the codec used for the AVI - using huffyuv of even indeo at highest quality will preserve things ok.
Panasonic DMR-ES45VS, keep those discs a burnin' -
So, basically, my only option is to convert it to from WMV/ASF to AVI and then from AVI to MPEG, right? Thanks!
One more question: Does stoik video convert ASF to AVI with no quality lost? Thanks!
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 08:47 -
Quicktime to Windows MOV-mpeg-4 conversion problems?
By Simone in forum ffmpegX general discussionReplies: 4Last Post: 16th Jun 2007, 06:50
