Ok, here's what I got, a SVCD movie which is divided into 4 discs. Now, I easily copied the MPG files off the SVCD's, but here is where the problem is. I want to merge them together, and then author them into a DVD. I have tried using TMPGEnc to combine the files, and it works fine for the first MPG part, but at the point when the second MPG part kicks in, the audio/video are out of sync. So, i tried using IFOEdit to make .VOB files and merge them. They merge fine and the audio is synced, but the IFO file says the movie is only 43minutes, which is the length of the first VOB/MPG file. By doing the SVCD -> DVD authoring trick listed on VCDHelp.COM, I am able to burn the DVD, but I have to make a main menu with a link to each of the 4 VOB file sets. I wanna combine it all so it wall runs as one long movie. Anyone help?
Justin
ok its real simple when u copied the mpegs of the svcds start rename all files 1 -4 now u need dvd to avi mow go file\open and select the first file u should find all 4 of the files in the file window double click on file 1 dvds window should now have the film ion it use the scroll bar at the bottom drag it all the way to the right you will now notice its all in one piece now go on file\save project and give it a file name i save mine in with the svcds but thats upto you once finished just encode in usual way so there is no need to merge...
if u have probs contact me on willmcmanus@hotmail.com
hope this helps
regards will
Authoring a home-made DVD problem
By elmuz in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2010, 08:28 -
Problem with authoring DVD folder
By nanook in forum ffmpegX general discussionReplies: 5Last Post: 20th Nov 2009, 03:40 -
Problem with DVD Authoring
By Astrogirl in forum Authoring (DVD)Replies: 1Last Post: 5th May 2008, 19:02 -
Problem authoring DVD from premiere elements
By foomandoo in forum Authoring (DVD)Replies: 4Last Post: 12th Jul 2007, 15:43 -
Problem with authoring NTSC DVD
By JPS in forum Authoring (DVD)Replies: 6Last Post: 17th May 2007, 14:33
