Stupid me, downloaded 2 halves of a movie which needed to have the .ac3 audio converted to .wav. I "accidentally" joined both halves of the video without first adding the audio to each half. Then (of course) I deleted the halves.
Can I still join the audio and add it to my whole video file? Please say yes! (but only if it's true)
You can use CoolEdit to join the wav files and I know you can also do this at the DOS prompt, but can't remember how.
Also, do a search in the forum for Join Wav Files and you will most likey find your answer.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Convert and join multiple m4a in one wav?
By astrosyn in forum AudioReplies: 1Last Post: 17th Nov 2011, 20:38 -
Join 2 uncompressed wav audio files
By kidcash in forum AudioReplies: 13Last Post: 11th May 2008, 02:15 -
How can i join wav?
By GangstaRap in forum AudioReplies: 1Last Post: 8th Jan 2008, 06:05 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
