ok i have a movie that is on 2 700 meg avi file and i want to encode then to 1 700 meg file usualy i us vertualdub and just compress then to a new size but now i am getting this error message on cd 1
And this on cd 2
its a simple question i know but i have looked every where so can some 1 give it to me in lame turms....................
oh and i have tried going to vertual dub audio options=>full prossesing and .wav => convertion => the chose lame mp3 codec with a 48000 hz
at 128 CBR but it is still out of sync on the finished .avi
please help its driving me round the bend
thanks in advance
Atr23200
You get that error message cause Virtual Dub cant handle MP3 VBR audio so you should use the "Vdubl_mp3_freeze" which can handle MP3 audio.
Download from here:http://www.digital-digest.com/dvd/downloads/virtualdub.html
Scroll down and you will find it. -
the link does not work do you want to send it
a.rampton@ntlworld.com
or do you have another link -
The link works for me,just tested it again and it worked but if you can+t get it from there,then try this link:http://www.donkey-tools.de/index.php?section=vdmp3
Encoding .TS to .AVI--Is AutoGK the best for it?
By babypotato in forum Video ConversionReplies: 5Last Post: 1st Aug 2011, 04:08 -
Encoding avi file
By chikchik in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2009, 23:21 -
Video_TS to Avi encoding
By macbuz in forum MacReplies: 9Last Post: 16th Jan 2009, 15:59 -
DV AVI to DV MOV - without re-encoding?
By arminio in forum Video ConversionReplies: 2Last Post: 4th Mar 2008, 05:42 -
Encoding AVI
By Broka in forum Video ConversionReplies: 32Last Post: 5th Dec 2007, 03:00
