Hi,
When I convert a Divx or Xvid file into VCD, XVCD or SVCD it doesn't go fluent. every second or so the video stops for about 0.5 sec. and then goes on, Its really annoying. Its only the video not the sound. Does anyone know what the problem is and knows how to solve it? please help!!!!
Thanks!!!
Does your mpeg play like this on your PC or is it only after burning. If it is the latter try reducing your burning speed.
When you can't get the LFE to result in what you want...
By takearushfan in forum AudioReplies: 0Last Post: 15th Feb 2012, 22:44 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
Does change of FPS of DVD result in any problem
By maass in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 07:58 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 22:32 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 14:58
