burn mpg vcd alright wit nero 5.5.9 but cannot read from the cd after burned
do i need plugin?
nice if you could help. TA![]()
if u tryed to open the mpg files on mplayer it probably won't play cause mplayer can open mpg2 but can't mpg2 wit svcd header ( burned in svcd ), for that u need a dvd player ( windvd, powerdvd ...) or a vcd/svccd player
Did you try to read the mpeg before burn with media player?? try to read your original mpeg from your harddrive with window media player,,see if it works... if it doesn't,,then their is something wrong with your mpeg..try to fix it with this guide
http://www.vcdhelp.com/forum/viewtopic.php?t=125214&highlight=repair+vcd
if it does work,,then you must did something wrong......
PLease state your situation in more details.. -
yes,i can read the mpeg on hd,it was a dat file from a vcd.
can it be protected eg(freelock)or bad config with nero,then how to config nero.
thanks again
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 06:14 -
Nero 6 Recode problem
By Rad17 in forum Video ConversionReplies: 3Last Post: 29th Mar 2009, 14:43 -
Problem with nero. I think!
By breeze9 in forum Video ConversionReplies: 3Last Post: 9th Jun 2008, 11:40 -
Nero Problem
By alley04 in forum Authoring (VCD/SVCD)Replies: 3Last Post: 6th Sep 2007, 18:08 -
problem with Nero
By moe_b_disc in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 05:13
