my prob is : i re-encoded a m2v that was to big for a 4 gb dvd and after it was done re-encoding ( to re-encode i used FFMPEGX) i used bit timcode on it. still outta sync , what do you guys suggest i try? ive done pleanty of searching and have asked questions on other boards. give me your thoughts. [/b]
Bits won't fix any sync problems you may have. If you want your file to be in sync then make sure you have the QuickTime MPEG-2 component installed and make sure you have the "QT decode" option checked in ffmpegX under the options tab.
hey man i appreciate the post but i got the component mpeg2 from apple and im still having sync probs , also it changes my widcreeen original to a box sort of . can you give me a step by step walk-thru of how i encode my original m2v file to something smaller to fit dvdr 4gb . my original m2v is 4.11 and my ac3 is around 400 mb. comes out too large . soory im new . please help.
Drop or Non_Drop Time Code
By sambat in forum SubtitleReplies: 10Last Post: 3rd Mar 2012, 18:13 -
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:56 -
Vista 64 bits with 32 bits programs
By skaleton in forum ComputerReplies: 9Last Post: 15th May 2009, 12:41 -
Most accurate way to record time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2007, 16:19 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 23:08
