i want to get this http://www.newzbin.com/browse/post/p/?ps_id=17535
but if you add it up its like this
cd1= 82 files x 13.6mb = 1115mb wich is 1.11GB
cd2= 78 files x 13.6mb = 1060mb wich is 1.06GB
can someone tell me if i were to dl this if i would be able to fit each cd on a 80 minute 700mb cd so i would have cd1 on a cd and cd2 on another cd
just seems like the filesize is way to big
i know the runtime of this movie is 114 minutes so its 2 hours
ANYONE HELP ME OUT HERE WITH ANY NFO?
You can try to compress it with Virtual Dub and choose a lower bitrate.
That's including the parity files presumably, so the output file size is smaller. If you download one rar file, WinRar might tell you the size of the output file. As long as it's around 830MB or less you should be able to write to an 80 min CDR.
You might want to remove that link from your message.
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 05:23 -
what heatsink/fan would fit?
By gooberguy in forum ComputerReplies: 5Last Post: 25th May 2008, 17:07 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 11:46 -
subtitle that doesn't fit
By Belfour in forum SubtitleReplies: 5Last Post: 14th Aug 2007, 08:30 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 22:57
