Take for instance two computers:
Comp 1- 2.7Ghz 512MB RAM (Memory running at 375Mhz)
Comp 2- 3Ghz 512MB RAM (Memory running at 333 Mhz)
Which of these will perform better??
So I would be better off running at 3Ghz rather than 2.7 with faster memory??Originally Posted by BJ_M
Originally Posted by mikef07
when u are talking raw power it is cpu but the mem speed makes a good dif. Take a AMD at 133 and a multiplyer of 14, then mod then mod the CPU and change to 200 and a miltiplyer of say 8 almost same CPU speed but encode time drops a lot. So amount of mem after 512 is not really needed but the speed of the mem makes a sizable diff. Hope this helps.
It depends on what your doing, but for the most part mpeg encoding speed will speed up based on CPU. However now that I'm using DVD2ONE primarily the CPU isn't the weakest link any longer, but rather the hardrives are. Having a good RAID setup will bennifet when writing or reading large amounts of data from the hardrive.
-Caleb -
I have the raid setup. 360GB of total HD space. Of option 1 or 2 which would u choose?
If your memory is so slow that it starves the CPU, your memory speed will need to increased. However, most memory nowadays is plenty fast for the processor (FSB > 100MHz).
So, your 3GHz machine will perform better (I'd say ~ 10% better).
There are things that can speed up encoding, by eliminating bottlenecks - like reading data from one physical harddrive and writing to another. Just bring up Windows Taskmanager and view the performance charts. You should see the CPU utilization at 100%, while your memory will be puttering along at around 10-20%.
memory usage of CUDA encoding
By sharkbite in forum Video ConversionReplies: 0Last Post: 25th May 2010, 23:36 -
Is There Specific Memory Rams for Intel/AMD CPU?
By imdaman in forum ComputerReplies: 1Last Post: 27th Nov 2009, 00:47 -
Low CPU Intensive video codec needed
By fitch.j in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:40 -
A short, simple, answer about core 2 CPU and DDR2 memory
By DB83 in forum ComputerReplies: 5Last Post: 9th May 2008, 20:59 -
New CPU:Video/Audio Encoding and DVD Authoring
By Maikeru-sama in forum ComputerReplies: 6Last Post: 29th Apr 2008, 14:56
