ok i haven't encoded/captured a video file in about two years. recently i captured some tapes to my hard drive in mpg and avi format. what i 'd like to do is add some background music in different areas of the video files. how exactly would i do this? can it be done through tmpgenc or v-dub? i used to do this sort of stuff quite often, but can't remember exactly how, thank you.
open file in vdub under audio select wav. browse for wav on your hard drive. that wil replace or add sound to file
sav as avi
done deal -
sounds good. and vdub will allow me to place the mp3 file that i want to add anywhere in the video file right? or will i have to convert the mp3 to wav, then add it?
1) Do you want to replace the audio or add voice overs? Replacing the audio is easy (just de-mux and re-mux with new audio track in VDub). For voice over you'd have to de-mux, edit the wav (eg. w/ cooledit) then remux.
2) It's not really necessary to convert the mp3 to wave, however to be on the safe side I would. Some MP3s use VBR encoding which can cause sync problems when muxed with another VBR video file (or even CBR video files). -
thanks for the replies, it's all coming back to me. now i have to re-capture using vdub because i origionally captured with "showbiz" capturing software, which isn't compatible with vdub, and when i use it in tmpgenc there are horizontal lines where movement occurs (i think this is called interlacing, right?).
btw, i want to combine about 5 mp3 files together and add them to my video. what is the easiest way to do this?
thanks for you replies and patience, i will pick all this up sooner or later -
Most non-linear video editors will allow you to lay down additional audio tracks or replace an audio track. Ulead VideoStudio would be an inexpensive example, Adobe Premiere would be a more advanced/expensive example of a program that could do this.
How Do I Add Music?
By Joshua P in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2011, 22:38 -
What is the easiest way to add or replace existing audio DVD sound track
By pwangdel in forum Authoring (DVD)Replies: 18Last Post: 2nd May 2011, 01:10 -
The easiest and faster way to add a watermark in my video
By morsino in forum Video ConversionReplies: 9Last Post: 10th Jul 2010, 08:51 -
easiest way to demux audio from DVD then add it back in?
By fotty in forum Authoring (DVD)Replies: 4Last Post: 12th Jun 2008, 08:46 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 04:35
