  1. Member Lantry03's Avatar
    Jan 2003
    I am trying to convet an XviD movie to MPEG so that I can write it out to VCD. With DivX files I have always used virtualdub for the audio track to WAV and TMPGEnc to convet it. When i try this with an XviD file I get an error that it cant read the audio in both programs. How do I get it able to read tha audio? or how else can I convert XviD to MPEG?
  2. does the xvid play on your pc (from the hdd)
  3. Member Lantry03's Avatar
    Jan 2003
    Yes they play beautifully, in fact they are the best quality movies I have ever found (as far as PC files go). They did not play at first, I had to install XviD and the Nimo pack less the ffdshow codec. I found help for that problem here - http://trendprofi.bei.t-online.de/xvidhelp.htm
    So now they play perfectly. I just can’t get them converted to MPEG.
    universe
    your xvid has ac3 audio which is 5 channel so it cant be read as such in those two channel (stereo programs).
    you must save wav from vdub as direct stream copy
    change the extension of . wav to . ac3
    convert the new ac3 file to wav with headac3he or besweet or whatever
    use the new wav as audio source
    convert to mpg
