I am converting an xvid file using TMPGEnc but when I hit frame number 47009 there is a problem and i get a blank screen from then on, the video before is fine. How do I solve this problem?
Like tenders says, you have a bad frame which although is not evident when you play the file causes the video to freeze during encoding. Scan the video for bad frames with vdub, when it reports the bad frames save as a new avi file with a different name with direct stream copy selected for the video and audio.
i tried doing that in vdub...video->scan video for errors..it scaned and found 1 bad frame...i then cliked on audio->direct stream copy then vdeo-->direct stream copy. after this i went to file and cliked "save as avi" and renamed to new file. once it saved tthen i opened the video in real player and it worked unitl the corrputed frame...the video then froze at that frame but the audio resumed......plz help
thanks in advance -
you can also try this: https://www.videohelp.com/forum/viewtopic.php?t=142555&highlight=
hope it works for you
Premiere Pro: Import/Export XviD & Frame Size Issues
By Cube11 in forum EditingReplies: 11Last Post: 6th Feb 2015, 20:43 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
How to cut xvid avi by a non-key frame
By Kirill in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 06:52 -
Standard XVID Frame Sizes
By adalect in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2010, 00:11 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 14:05
