Hi,
I made a SVCD with still images. Almost everything went well, even interactivity with menu, but my DVD player (Pioneer DV-454) reproduces distorted images. A circle becomes an ellipse horizontally streched, because vertical size is reduced and I have 2 black strips on the upper and on the lower sides of the image.![]()
Changing the DVD player settings is useless.
This happens with each one of the forth resizing methods.
If the svcd is played by a PC player (PowerDVD) the images are right (without any distortion).![]()
Can anyone help me?
Paolo
I have a solution which work also for me (I have the same problem with SVCD but not with VCD).
You must set your DVD in 16/9 (wide) and when you have started playing your Disc change you TV to 4:3 mode and then your pictures will have the right size. This solution work on a 4:3 Tv and I don't know if it works on a 16:9 TV.
hmm.... interesting. I'm going to try that TV switching aspect ratio. As far as I know, SVCD still image creation made by VCDEasy v1.1.5 and v1.1.4 gives distorted image. I'm assuming the same happens for VCD still as well. I haven't tried that yet, however. The only version that works is v1.1.2, and has never failed me. So I'm keeping 2 versions.
Standalone player that will play ISO images of DVDs
By whatever911 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 30th Sep 2011, 12:58 -
Pioneer 420k DVD player for canadians
By victoriabears in forum DVD & Blu-ray PlayersReplies: 47Last Post: 30th Aug 2011, 10:26 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 08:55 -
What is the best freeware player to play ISO images, mpeg, flv, etc
By avz10 in forum Software PlayingReplies: 0Last Post: 27th Jun 2010, 15:16 -
BD-R no longer plays on Pioneer BD player
By sapiendut in forum Blu-ray RippingReplies: 0Last Post: 27th Sep 2009, 08:38
