Recently I have downloaded a Xvid movie from the net which has AC3 audio. I scan the avi for bad frames and 1 bad frame and 55 unencodeble frames were detected so i decided to strip the audio first using virtualdub before fixing the avi to avoid the audio sync problem I will later encounter while encoding it to mpg.
I got an error that I can strip the audio with virtuadub cause the compresssion is not compatible with the input format. Then I decided to strip the audio without converting and then renaming the wav to ac3 and using headac3he to convert it to a wav just like King John's guide.
It worked but after doing until 40% headac3he says that the audio frame is bad and then conversion will fail.
Can anyone please help me cause I realy want to burn this movie on a vcd cause it has great quality and I want to burn it without significant quality loss.[/img]
If your AC3 audio is bad then you can fix it with a tool called ac3fix which you can find in the tool menu.
I have never done used it before so I donīt know if it work but itīs worth a try.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
VIDEO_TS to AVI xVid with AC3 5.1 passthrough - problems
By couldtryharder in forum ffmpegX general discussionReplies: 11Last Post: 29th Nov 2011, 09:08 -
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 21:58 -
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 03:25 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 15:16
