Hi,
I used DVDx to test run a short clip=>divx, in the divx5 pro bitrate setup screen after i presses "select" for the 2-pass log file selection, the 1st time you can type whatever log file you want to name it and press "save" but after that i deleted the .log (no longer needed, i thought) and from then on the "save" becomes a "select" since the .log is gone DVDx comes up with "Could not open log file for reading"...
i know that the .log is created for the second pass but my question is how do u make that "select" button turn back to that "save" button...
Can someone please help me with this problem...
just restore defaults in the DivX codec configuration from withing Vdub (select teh DivX codec, the hit configuration)
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for the reply
But sorry to nag you im a newb, under which tab can do i go under in virtualdub to select divx codec??
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 19:24 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
Can not log onto PC
By Noahtuck in forum ComputerReplies: 19Last Post: 12th Dec 2009, 22:35 -
Log in?
By alintatoc in forum ComputerReplies: 10Last Post: 5th May 2009, 02:04 -
DIVX 3 to DIVX5
By munozsblazer in forum Newbie / General discussionsReplies: 13Last Post: 9th Mar 2008, 12:05
