When authoring the same movie to VHS tape and vcd or svcd, why is the tape quality better than the vcd or svcd. I would have thought it would be the same at least.
TIA,
Zap
Could you describe your proceedure for "authoring the same movie to VHS tape" for us? Do you have a VHS drive on your computer?
OK, I'm being a jerk. I suppose you are saying you've authored VCDs and SVCDs from source material captured from a VHS tape. Now then, you are wondering why a copy doesn't look the same or better than the original? Good question. Hope someone can help.
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 16:58 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
hiss removal on a good quality VHS tape?
By zee944 in forum AudioReplies: 78Last Post: 26th Mar 2009, 05:28
