I was wondering if anyone has been successful or found a way to turn off the copy protection schemes on the Panasonic DMR-HS2?
I have several VHS tapes of old that I would love to put on DVD but the DMR-HS2 just wont allow me to do that. I constantly get the message
"Copying of this material is not allowed"
Does anyone know of a device or a firmware mod that can assist in this?
Thanks,
Results 1 to 12 of 12
here is something you may want to look at
http://www.videoasylum.com/ht/messages/14308.html
apparently it works and I have seen it mentioned all over the place.
I dont own one myself. -
Originally Posted by pan-dmre30s
Thanks for the info. I actually have this item and although it works great on most, there are a couple of older VHS tapes that it will not allow the Panasonic DMR-HS2 to copy. I happen to know the builder and this is something that is an ongoing dilemma. -
I am curious even more now about how old the tape is
and especially what movie.
Is it before 1986?
Maybe not a solution but could you possibly try this
2 stage duplication out of curiousity
Copy stage !
Source TAPE --> dubbed TAPE
Copy stage 2
dubbed TAPE --> DVD-R -
The movies are before 1986 and we have tried so many things without success. We tried what you suggested as well. -
How is it possible that the device above has worked for ANY of your VHS tapes at all? If it does CGMS and not Macrovision then how does it do any good on the VHS tapes?
***HACKED! GE-1101P DVD Player**** DVDR985 DVD Recorder soon to be! -
Ok, this has "bothered" me as well for copying VHS to the HS2, not copy-protected VHS, but Regualr VHS Videos.
I'm not sure how to tell if it's just a bad tape, or MAcrovision screwing things up.
Keep in mind this stuff was shot on an AV Camcorder in the 80s or recorded off of the TV and isn't avilable on DVD or even VHS for the most paert, I edit my VHS tapesand go to ut them on DVD and some work on one VCR and don't work on another, is this normal?
I have an old and a new Sony VCR and the older one records with minro problems, the enwer ne records with "Wavy" lines but plays the vdieo back fine. I don't get any "Error Messages" but the wavy lines disturb me, is this Macrovision wreacking havoc from VHS to DVD, or is it kjsut a bad tape?
I though Macrovision was only supposed to screw up DVD to VHS, not the other way around. -
Originally Posted by Playdrv4me
have you tried these configurations
source vcr -> secondary vcr --> filter --> DVD recorder
or
source vcr --> filter --> secondary VCR --> DVD recorder
What have you tried we would like to know what does not work. -
Some tests I ran just to see what happens with my old tapes.
(all my copies so far had been non commercial off air tapes )
I used a JVC SVHS VCR model HR-S3600U
connected to panasonic dmr-e30s using S-Video.
No filters of any sort were used.
Taped a few seconds onto DVD-RAM from these few VHS Original tapes I own.
Magnetic Media Corp - 1980 Okay (video great for 22 year old tape)
Trans World ??- 1980 okay
warner brothers -1984 Okay
Lightning Video - 1987 Okay
Media - 1989 Okay 1987 - failed (expected opposite)
A few other 1990's tapes from small release studios recorded fine in the test.
A couple of other tapes copied but the resultant video was worse .
None of the tapes were major blockbusters but they are all old out of print
and good candidates for digital preservation.
I would like to try and get a copy of your tape to test it.
What tape is it, or at least what studio and year is it. -
So actually at this point I am quite content since out of over 1000 vhs tapes I am really only down to one that could not be copied as of yet. If I find a way to do it I will post it here. Take care!
Panasonic XW380 problems
By Skiwi in forum TestReplies: 0Last Post: 20th Apr 2012, 22:19 -
Panasonic DMR EH59 - Software to remove copy protection from sattelite TV
By bjuice in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2012, 11:50 -
Direct Stream Copy of Panasonic MTS files
By Bjerner in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 15:03 -
Problems with Panasonic AG-1980
By henryperu77 in forum RestorationReplies: 1Last Post: 10th Jun 2009, 11:54
