I am capturing to SVCD MPEG2 with a Hauppauge PVR
I have selected SVCD format to capture to,
I am using WinOnCD, but it says the captured file is non-compatible.
I have a hauppauge program to convert appropriate MPEG1 files to VCD compatible, but not SVCD
What application should I use to do the last bit of conversion?
thanks
John
John of Rotherham
jpowell@ecclesall.demon.co.uk.nospam -
Since it is MPEG-2 already demultiplex with TMPG and multiplex again with bbMPEG. Hope this helps.
And of course have we guides for that...follow this, just skip the cutting part
http://www.vcdhelp.com/bbmpegedit.htm -
On 2001-09-03 15:45:12, BigGash wrote:
Does WinOnCD write VCDs?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
yes -
thanks for the replies - starting to get some success
can get WinOnCd to accept MPG files now, and can write SVCD, next task is to get Samsung 709 to accept (may be futile)
thanks John
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
