have an occasional problem when converting avi to mpeg and using virtualdub,
when I start virtualdub and select video source I get a message that there are, for example, 31910 ms of skew, do I want to carry on.
I just carry on and the output file has a noticable lag in the sound and video.
Any advice on how to correct this, have two films that are affected
The warning screen is telling you that its VBR, read what it says !
Audio > full prosessing mode
Audio > SAVE WAV
However, you must check it for bad frames, and so you would use Vdub MP3 and not the normal Vdub.
KingJohn's Guide to bad frames V2 VBR Update
thanks for the advice, only just started at this stuff, was doing ok til got this for the first time,
think I just didn't read it properly
I knew I would get good advice here, learn't a lot just browsing site
Is this the correct way to install ffdshow just for VirtualDub?
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2013, 01:23 -
Can VirtualDub correct audio drift?
By Djard in forum EditingReplies: 9Last Post: 26th Oct 2009, 18:33 -
How to add/fix audio skew in VirtualdubMod?
By neomaine in forum Video ConversionReplies: 2Last Post: 4th Jan 2008, 13:27 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09 -
Problem with SKEW audio
By themaster1 in forum EditingReplies: 0Last Post: 22nd Jun 2007, 21:35
