  1. Guys please hlp me : im going crazy
    ill list what i did in steps so you guys can tell me exactly where i went wrong :
    Ive just converted an XVID with ac3 to SVCD - of which the XVID was originally out of sync. after watching the out of sync mpeg,
    (1) i demuxed, and converted the audio stream mp2 file into a wave using headac3he, using the default options.
    (2) i then fixed the out of sync a/v with virtualdub's interleaving option. I then use the wave file as audio output to watch the movie to fix up the out of sync. i then use full processing mode to save my wave file.
    (3) now, the video is fixed up fully. in virtualub, the movie plays
    perfectly in sync in tandem with the wave file that i created.
    (4) I then convert the wave file back to mp2 using headac3he. I then remux the mp2 and m2v files into the mpeg NOW :
    technically, the mpeg should play perfectly in sync like it plays in virtualdub shouldnt it? but it doesnt !!??!?
    why is that? PLease help! I really need this file!!!
  2. what i do is i load film into gold wave mark a small section about 5mins of the beginning audio and copy to clipboard then i mess around with the sync i save the small wav i created and try a small encode when all is well i alter the sync settings to the full audio and save it then reencode film works great.
    regards will http://www.cdcovers.cc/cover_software.php
