i have been following the tutaral on how to fit a dvd on to one cd as a vcd but all my videos end up being 1.099 gig in size and will not fit on a cd ,
I set tmpgenc for 100% of an 80min cd and it says that the file will be 799mb but ends up being 1.099gig
i have set it for 2-pass vbr as "the newbies guide to fitting a movie on one CD using TMPGEnc" says all settings are the same and i have made sure mpeg1 non standed is selected could someone please help![]()
Be sure not to use version 2.59 of TMPGEnc.
There is a bug about mpeg1 non standard, corrected in 2.510, that make VCD as if they were standard.
Hope it helps.
Riccardom -
Thankyou for your help i was using version 2.59 have changed to 2.51 and it works fine now thanks
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
