When I used SmartRipper to rip the movie "The Fast and The Furious" I got three long files, each with just commentary on it. There was no sound from the actual movie at all.
What should I do to get just the movie and it's sound?
Thanks.
If everything is infinite then nothing is definite.
i dont know if this helps, but in smartripper, in the input tab, there should be stuff about title, program chain, angles..so what you gotta do is find the one which is the actual movie. all the other stuff should be special features like the commmentary.
FOL furious with McAfree ap that auto loads with either Flash, Java or..
By edDV in forum Newbie / General discussionsReplies: 0Last Post: 7th Sep 2011, 00:02 -
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 16:37 -
Software Recommendations - WMV-Support / Trim-&-Join Capable / Fast Enc
By Chimera07 in forum EditingReplies: 2Last Post: 25th Nov 2009, 17:55 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 12:54 -
How Can I Separate DVD Music & Commentary's Voice?
By Aaron1927 in forum AudioReplies: 5Last Post: 10th Aug 2007, 18:28
