  1. To recieve an hdtv signal what do I have to do? I know that the signal is not coming in through normal analog cable, or through digital cable at least not with at&t cable, or I just dont notice any difference. So if I just watch normal networks like nbc on the tv, when its not hooked up to cable, will I be recieveing it in hdtv?
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I'm no expert but I think you may need an HDTV antenna, also you may need an HDTV decoder if you TV didn't have one built in.
