Major,
Tried converting an avi and adding subtiles, but it didn't seem to work. No "burned in" subs were seen in the resulting mpeg. I followed the instructions as you wrote them in the release "changelog". The only think I can think of is that I had installed all of the subtitle packages instead of just the "Subtitles iso-8859-1.pkg" by error. Not sure if there is a conflict going on and I couldn't figure out how to uninstall them to check if this theory was correct.![]()
Yes
Me too, I can't incrust subtitles (.sub, .srt....) into my divx. With mencoder, it works but I can't directly encode in mpg1video. I must encode in mjpeg in order to encode in ffmpgX.
So, I followed the instructions in the ffmpegX's "changelog", but nothing.
My presets in ffmpegX:
avi (divx) to VCD via mpg1 mpeg2enc
load subtitle (with mplayer decode)
Subtitles package instaled.
I don't understand ????
iMac DV ES 400 640 Jaguar 10.2.3 / 9.2.2
Disque ICE FW 60 Go / Iburner 40x FW
http://www.macdk.com/
Forum donkey français MACCCCCc
OK, thanks.
I'll try to create CVD. But with my iMac 400 DV, Mpeg2 encoding takes a very long time.
FFMpegX - NOT seeing VOB's imbedded subtitles...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 14th Jan 2012, 10:10 -
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
dvd conversion + greek subtitles + ffmpegx
By eleeeni in forum ffmpegX general discussionReplies: 1Last Post: 10th Sep 2011, 12:10 -
How to add hardcoded subtitles to WMV using ffmpegX
By Vitoarc in forum ffmpegX general discussionReplies: 0Last Post: 12th Mar 2010, 12:42 -
FFmpegX Subtitles Position not working
By kidart89 in forum ffmpegX general discussionReplies: 2Last Post: 8th Nov 2008, 21:02
