Hi I followed the guideline on this website for making a vcd but it still doesnt work.
Once I finish burning, all that is on the disk are the vcd components and there is no video clips.
When making the vcd, it shows that there is my 4 video clips and the menu, but when completed there is no video clips on there.
Can someone plz tell me what I'm possibly doing wrong or what I need to do, thanx??
i think you're trying to find the .mpgs in the vcd but there are none. to watch it, go to the MPEGAV folder and play the .dat files with windows media player or get a program to play vcds
What kind of program do you need to play vcds?Originally Posted by asdf
I have windows media player(which says it doesnt support that format), Nero Burning Rom with Nero Express 5.5.
When I go into the cd after burning in MPEGAV there is 4 files(which i think i my video clips) and they say "Avseq01,Avseqo2,Avseq03,Avseq04"!! It comes up with mediaplayer but says the file cannot be play "MMSYSTEM281".
Plz can someone help me?? -
the left of this window..there are menus. or just go here http://www.vcdhelp.com/tools
Dabwee:
"Avseq01,Avseqo2,Avseq03,Avseq04" those should be the clips. They should have a .dat extension. The easiest way to play without any VCD or DVD player software, would be to right click one of those files and select, open with and then Media Player. Then that individual file should start playing in Windows Media Player.
Making Someone Look Bad :)
By HoosierGuy in forum EditingReplies: 9Last Post: 16th Dec 2011, 14:37 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 06:53
