Just notist that Nero just release another version today. This one is 5.5.10.7b. They did release one eihter last Friday or Saturday but this is a newer version.
They also list the DRU500 on they compatable list.
Results 31 to 42 of 42
Lets see if this helps.
NERO: 5.5.10.17b { latest as of 2/3/03 }
MFG DATE: Jan 10 2003
Version: BD
FIRMWARE: flashed from 1.0e to 1.0g { Received set as 1.0e! }
MEDIA: Verbatium DVD+RW 2.4x
OS: W2k SP3
CPU: Pentium III 866mhz
RAM: 256mb
MS DRIVERS: Stock for drive.
CHIPSET: VIA
Have only has time tonight to burn a Data DVD of about 1gb of small files but had no problems.
PS: Both of the Buffer guages hit zero a few times! Did a verify on the data and it passed. Wont know untill I can produce a video to burn as a DVD-Video if both g and Nero are working as desired. -
I have flashed to 1.0g and see no visible improvements or added problems, yet. I must add that I have no problems and have never had any problems with with my 500a, banging on desk. I did get 2 riteks from a friend that were supposed to be 4x after using the media identifier I learned they are really only 2x so I still don't know if my drive will burn 4x yet.
Manufacture date of the drive is 28 October 2002 Version BA (whatever that is) -
what i am interested in, is whether or not the 1.0g firmware allows for 4x read of dvd-r movies or retail dvd discs, as opposed to the 2x that 1.0f allows. anyone know yet?
I have a friend that get almost 4x off of a DVD read only drive. Thinks its a Toshiba or Teak. If I get a chance today will run a test for you.
Also need to find some cheep test media at 4x. -
-BK- another few thoughs:
* Check IDE Drivers
* Check motherboard BIOS updates
* Check PSU has not gone bad (I'm using 350W Enermax)
An unrelated update could have caused the problems, I've been there before. I re-installed Windows and everything was OK. -
I don't use the DRU500 to rip DVD's but tried just now before updating to 1.0g and got 2x, and after still got 2x.Originally Posted by jeffreii
Hope that answers your question. -
Did a rip to test some other stuff using DVDdecriptor and it did max at 2.0x with 1.0g on Win98se
Just out of curiosity, have you installed DirectX 9? For some reason, everything worked swimingly for me until I put DX9 on my box. I was NEVER able to get the drive going at 4x with the VIA chipset, so I installed it on a new box which worked at 4x until I popped DX9 on (nothing else mind you, I tested it stage by stage) and viola... 2x after 2 mins.
DC -
Wow !!
I run XP with SP1 and DX9. I have noticed DVD9 rips max out at 2x. I guess 1.0g does not speed this up so, I think I'll pass on it for now -
Well, you know me. I had to update.
I put the file on my desktop. Re-booted into Safemode. Ran it and it upgraded from 1.0f to 1.0g with no problems. I rebooted after installation. I checked the ripping speed and unfortunately it still maxed out at ~2.0X.
No harm I guess. Hopefully I'll experience are some other benefits with this upgrade
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 23:46 -
firmware page
By MEL15 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd May 2008, 08:43 -
Upgrading firmware
By tee jay in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th Feb 2008, 14:35 -
Daytek firmware
By DereX888 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 10th Feb 2008, 14:32
