Still Sequence menu
Still sequence menu is quite a lot of work in DVDMaestro so it is recommended use the normal Subpicture menu instead.
Anyway you design the Still Sequence menu in DVD Menu Studio as a Button menu.
To see how to design Button menu - see guide on "Making Button Menu's in Maestro".
First create a series of BMP file as per the button guide.
This will create series of BMP files. If you have 3 buttons, this will create 3 files.
Import in DVDMaestro
1. Right click in the Asset Bin to open menu and select Import media Assets and load all the *.bmp files. Alternatively you can drag and drop the files to Asset Bin from explorer.
2. In the Project Tree, create the same number of menus as you have files.
3. Open each empty menu and drag and drop one of the imported file there as background. In our example you will have Menu1 with menu_1.bmp, Menu2 with menu_2.bmp and Menu3 with menu_3.bmp
4. On the Menu1 create button around the first item. In the Buttons Tab set the properties as Invisible.
5. On the same Menu1 create button around the second item. In the Buttons tab set Invisible and Auto-Action. In the Target set Menu2 . Create button around the third item. In the Buttons tab set Invisible and Auto-Action. In the Target set Menu3
6. In the Tab Advanced click Auto Assign in the navigation group.
7. You have to repeat the steps 4-6 for the other menus with this modification:
Menu2, Create hotspot around second item set Invisible, create hotspot around first item, set Invisible, Auto Action and target Menu1, create hotspot around the third item, set Invisible Auto Assign and target Menu 3, then Auto Assign.
Menu3, Create hotspot around third item set Invisible, create hotspot around first item, set Invisible, Auto Action and target Menu1,create hotspot around second item, set Invisible, Auto Action and target Menu2, then Auto Assign.
Basically in other words on each menu first create hotspot around the item which is Highlited on the background and set it as Invisible
Then create the remaining hotspots on that menu and set Invisible, Auto-Action and target the respective menu.
8. Now in Connection put Menu1 as target for First Play. Hopefully you did everything fine and you can test it.
9. To link the Movies to each menu simply from Connection link the Movies to the Menu#: Button # which is still not assigned.
Results 1 to 1 of 1
GUI for dvdauthor problems – Strange menu sequence behavior using Henc
By jsbullock in forum Authoring (DVD)Replies: 9Last Post: 20th Feb 2009, 03:44 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 07:02 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59 -
need to make a menu
By m-man in forum Authoring (DVD)Replies: 2Last Post: 5th May 2007, 05:19
