Hi, I have a problem.
When I tried to open an AVI file in winXP I got this error:
"Couldnt locate decompressor for format "DIV3" (Microsoft High-Speed MPEG-4 V3 [Hack: DivX Low-Motion])
VirtualDub requires a video for windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
I have install DivX 5.0.2 and the movie play fine with wmp 7.1 and realOne player.
I use Virtualdub to open the file is because I need to use it to extract the AC3 from the avi and then save it to .wav. After that convert it to VCD with TMPGEnc
I able to do the task in win 98, but not win XP. Can anyone help me to figure out the solution so that I don't have to use two PC to do the job. Thanks....
p/s: I post the same topic at other forum, some ask me to install Tsunami-patched DivX 3.11 codec, use nandub or virtualdubMOD instead, but all don't work. The error prompt once I click "Open video file" --> "Open"
The codec your missing Is DivX 3.11 alpha, it comes with 2 types, low motion and fast motion.
This will help
KingJohns Guide to Codecs V2
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 08:06 -
HC Encoder -How to open AVI files
By MI6 in forum Video ConversionReplies: 6Last Post: 30th Nov 2010, 14:15 -
How can I open iPhone 4 H264/AAC .MOV files in VirtualDub?
By Syclone0044 in forum EditingReplies: 1Last Post: 24th Nov 2010, 05:18 -
Help! Error When Attempting to Open MOV files in Virtualdub!
By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2010, 12:30 -
Possible to get VirtualDub to open wmv/flv files without ffdshow?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2008, 20:09
