Hi all,
I have some material I shot some time ago encoded as MS-MPEG4 v2, 3000 kbps, 1 keyframe each 30 frames.
I get a crash at Premiere 6.5 when I try to open some of those files (not all of them). A friend told me the temporal compression is likely to be the root cause to those crashes, hence to solve them I should convert those files to I-frame only. He also told me it might possible to do so without having to reencode the keyframes. My feeling is that adding 29 keyframes per second (even when raising the bitrate to the maximum of 6000 kbps) will ultimately degrate the spatial compression (within the keyframes).
Does anybody know if thatīs true? And how should I proceed?
I am willing to do it that way, instead of using another codec, so I donīt any new types of losses.
Thanks for you help,
Pedro
Results 1 to 1 of 1
Multiple Mpeg sources per frame without reencoding
By bisonrav in forum Video ConversionReplies: 1Last Post: 17th Sep 2011, 06:28 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Add chapters to MPEG4 MOV without reencoding
By Jonya in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2010, 17:41 -
Add JPEG as First Frame - Windows Explorer Preview - Without Reencoding..
By aces27 in forum EditingReplies: 1Last Post: 28th Feb 2008, 10:07 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
