  1. When frameserving from VirtualDub to TMPGenc, should the video be direct stream copy or full processing mode. I always encode audio seprate so it's just the video I'm concerned with.
    Any help would be greatly appriecated.
    Dobbs
    Australia
    If you are not applying any filters during the frameserving then select 'Direct Stream Copy' that way you stream the pure AVI.
    You only need 'Full Processing Mode' if you want to edit the AVI (e,g, resize, de-noise etc).
    Mar 2002
    United States of America
    Direct Stream Copy is used when you want to save out another copy of an AVI file without re-encoding. :P
