  1. just multiplex my svcd with tmpgenc.
    now playing it with power dvd and i can't get the second language to play.
    not even available in the menu.
    even using windvd and can't get the second audio track to work.
    any help would be great thanks
  2. Member adam's Avatar
    Sep 2000
    From my experience, software support for dual audio tracks in a SVCD is very sketchy. Sometimes it works fine by just using file mode and loading the mpg. Other times, I can only get it to work if I actually burn the disk, or mount the image, and play the movie in disk mode. You can make a bin and cue image in VCDeasy and then use Daemon tools to mount it.
    In any case, it should always work on a svcd compatible hardware player.
