Im a complete and utter newbie, and I have enjoyed a lot of the how-tos and the guides in here.
I used easydivx to make a DivX movie - worked like a dream.
Then I was thinking about how one would downsample a DVD that was DualLayer-DVD9 to a one dvdR of 4.7gig.
Well, I found DVD2ONE, and it worked like a dream.
I used DVD-DECRYPTer to rip the movie - again, worked like a dream.
but now Ive got four files of more than one gig a piece.
THEN I used VOBMERGER til merge these vob files.
Everything works like a dream - no errors at all.
but one ..
Now I want to put this darned movie onto my dvd+rw disc of 4.7gig. And I cant find any decent software to actually do this! Ive got RECORDNOW, but it doesnt want to burn anything but IMG or ISO.
Now, I know (after the fact, of course) that DVD DECRYPTer rips directly to ISO, but is there really no way for me to get this large VOB file burnt onto a disc?
I see that a lot of people use the .IMG format, but how do I turn my .VOB into a .IMG?
Im at a loss!![]()
So naturally I ask you guys - you seem to know everything!
The Don
The Don -
First of all why did you merge the VOB files created by DVD2one. Leave them as is.
Update to Recordmax DX
http://dl1.easy.co.jp/rndx45_e/splash/regist.html
Create an empty AUDIO_TS folder for ex. C:\AUDIO_TS
Start Recordmax DX
exit the wizard in recordmax. Choose create a data disc.
drag over the audio_ts folder and video_ts folder that dvd2one created.
and burn with recordmax.. -
Thanks! I will try updating the software, and see if your tip works (im sure it does.)
The reason I merged them, to tell you the truth, is because I was under the impression it was just to burn away.
Thanks again,---
The Don -
... still
How do they mage those .img files, though?---
The Don
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 09:36 -
PROBLEM RIPPING DVD+RWs FROM LG DVD RECORDER
By i am x in forum DVD RippingReplies: 11Last Post: 27th Aug 2010, 18:39 -
Ripping a DVD, editing it, then putting it back onto a new DVD. HELP!
By CaptainZissou in forum MacReplies: 11Last Post: 7th Feb 2010, 00:18 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11
