I have Hardware mpeg encoder card
In manual tell me that can capture mpeg for VCD1.0
So i doubt mpeg for VCD 1.0,1.1,2.0 are different or not?
And Can I burn my mpeg file to VCD1.1 or 2.0 ?
DESCRIPTION FROM MANUAL OF VCDImager software:
"VIDEO CD 1.1
This is the most basic Video CD specification dating back to 1993(6), which has the following characteristics:
One mode 2 mixed form ISO9660 track containing file pointers to the information areas.
Up to 98 multiplex-ed MPEG-1 audio/video streams or CD-DA audio tracks.
Up to 500 MPEG sequence entry points used as chapter divisions.
The Video CD specification requires the multiplex-ed MPEG-1 stream to have a CBR of less than 174300 bytes (1394400 bits) per second(7) in order to accommodate single speed CD-ROM drives. The specification allows for the following two resolutions(:
352 x 240 @ 29.97 Hz (NTSC SIF).
352 x 240 @ 23.976 Hz (FILM SIF).
The CBR MPEG-1, layer II audio stream is fixed at 224 kbps with 1 stereo or 2 mono channels. It is recommended to keep the video bit-rate under 1151929.1 bps(9).
VIDEO CD 2.0
About two years after the Video CD 1.1 specification came out, an improved Video CD 2.0 standard was published in 1995. This one added the following items to the features already available in the Video CD 1.1 specification:
Support for MPEG segment play items (SPI), consisting of still pictures, motion pictures and/or audio (only) streams was added. See section 2.6.2 Segment Items.
Support for interactive playback control (PBC) was added.
Support for playing related access by providing a scan point index file was added. (`/EXT/SCANDATA.DAT')
Support for closed captions.
Support for mixing NTSC and PAL content.
By adding PAL support to the Video CD 1.1 specification, the following resolutions became available:
352 x 288 @ 25 Hz (PAL SIF).
For segment play items the following audio encodings became available:
Joint stereo, stereo or dual channel audio streams at 128, 192, 224 or 384 kbit/sec bitrate.
Mono audio streams at 64, 96 or 192 kbit/sec bitrate.
Also the possibility to have audio only streams and still pictures(10) was provided. The bit-rate of multiplex-ed streams should be kept under 174300 bytes/sec in order to accommodate single speed drives."
When I burn my VCD's I use VCD 2.0 (also it's a Nero template).
I hope help you.
